Yes, this'll be important.bledd. said:make sure you've got a 64bit cpu first![]()
No, you don't have to get a 64-bit OS. It'll work just fine in 32-bit mode. However, since 64-bit is the way ahead it's somewhat silly not to get 64-bit OS.j0nnyd said:does this mean i HAVE to get a 64 bit?
BillytheImpaler said:With 64-bit XP drivers were an issue. With Vista this is no longer the case as MS is requiring manufacturers to support both 32 and 64-bit Windows in order to be certified.
mwtb said:The problem here is that a lot of hardware manufacturers have never bothered to get their drivers signed. Seeing as Vista 64 will simply block any unsigned drivers, you'll be up the proverbial creek without a paddle if you have or buy such an item. Personally, I don't recommend anyone to get Vista unless they're buying new kit anyway and I don't recommend Vista 64 to anyone.
modo77 said:Really?![]()
SideWinder said:Yes.
(lol at me if i'm wrong...)
That's because it's not really emulation...eriedor said:I'm sure I've read about Vista 64 having a really good 32 bit emulation so 32 bit support is no problem.
