Masterdog said:Dual booting 32-bit XP and 64-bit Vista is probably the best option at the moment as you say
can't fault that
modo77 said:I'm not saying you should enabled unsiged drivers I'm saying you can. As you said you'd be up a creek without a paddle. Well thats not true since you can use them. However since dodgy drivers cause most faults it makes sense they need to be certified so that this issues are limited.
Also does anyone actually use 16bit software anymore? I'm sure some obscure program might only be 16bit. But lets be honest you have to get the balance between advancing the tech and legacy support.
Yes.mcwildcard said:So does a 64-Bit OS run faster than a 32-bit one then?
I don't mean with installed apps/games, just the actual OS UI itself.
Cheers for the speedy reply, is the difference really noticable?NathanE said:Yes.
modo77 said:You can use unsigned ones in x64.
Vistabootpro for one, gives you the option to enable the use of them.
Lysander said:But what are the practical benefits of having Vista 64 over 32? I have Vista 64 and notice no difference. Yes, OK, 64 is the future but what are the real advantages??
Games are getting to the 2GB barrier now. Sooner or later you will only be able to play games with hi-res textures etc on a 64-bit OS. For the simple fact that eventually they just aren't going to be able to fit it all into memory!Lysander said:But what are the practical benefits of having Vista 64 over 32? I have Vista 64 and notice no difference. Yes, OK, 64 is the future but what are the real advantages??
Energize said:None unless you have 64-bit applications. There was 1 game that supported 64-bit I think......
v0n said:64bit, as it is presented now by MS and the way it is treated by manufacturers (neccessary evil) has no real advantages to regular user unless you run services that require more than 4Gb of memory.
same hereDurzel said:As a relative Vista newbie I went with 64-bit purely for the future-proofing reasons. I had expected lots of problems due to the fact that I knew that XP x64 wasn't well supported in drivers, but everything has been seamless. I haven't had any problems at all - although I would stress I'm not using any esoteric hardware (just ATI, Creative, Intel, ASUS, etc stuff)
leaskovski said:Does this allow you to set 'allow unsigned drivers' as default, as i am constantly booting via the F8 menu at the moment?
Thanks
leaskovski said:Just as i thought. The option in Vista Boot Pro doesn't work.
Does anyone know how to tell Vista 64 to always allow unsigned drivers without having to go through the F8 boot process?![]()
