3200 venice max temp
7 Mar 2005
Wolverhampton
Hi,
At what temp (under load) should i get worried at with my cpu? Trying overclocking but i get BSOD at 2.6 in games. Atm i think speed fan says its hit 43 ish max during me playing wow.
Is this safe temp? Thanks
EDIT - Sorry, found out its about 60, :)
Townlea said:
Yep thats a safe temp :) (actually a really good temperature)
I hope speed fan is reading it ok then !....im not sure which is which because it just says temp1 temp2 temp3 for the first 3, the next two are labled as my HDD.
So which is which? and is this speed fan very reliable to go by? Is there another program i can try to get a "2nd oppinion" ? :p
That is with cpu at 2.5, Need For Speed Most Wanted running, WMP, MSN and a download.So which one is my cpu and grfx card?
CCC says my grfx card is at 58 :confused:
(Yes sorry, i am new to this, this is my first ever build )
With most of my Mobos, temp 2 is the CPU Reading.
So, on that note, I would say that your CPU temp is according to the readin,g at 39c
Lurvely
Thats the same as this PC is right now.
Camalot said:
Hi,
Getting 2.6 with the asrock motherboard and a 3200 venice should be a piece of cake, set it to CPU/PCIE Async up the FSB to 260 and stick everything else on auto (disable the memory compatibility mode) works on mine like a charm.
Will definately need to use a memory divider for 260HTT with Geil Value.
