In terms of comfort type features there isnt much in it between the SE and Sport. In fact if you want a car the rides better and cruises the motorway better then you are better off with an SE.Jonny ///M said:I cringe when i see a 330 in Se form,whats the point in going for the highest model but with a lower trim level.
The_One said:But sports are fetching 3k moreand in cases up to 4k.
Are they really worth the extra pennies![]()
bobert50 said:hmm are the M-Tech Sports Seats in the sports version the suede ones that really look the part?
theres nothing worse than ripped leather seats in old bimmers !
Mr_Sukebe said:Mine are leather, with no signs of wear at all. Fox will be able to comment better on wear as his motor's done 140k+.
Joe T said:In terms of comfort type features there isnt much in it between the SE and Sport. In fact if you want a car the rides better and cruises the motorway better then you are better off with an SE.
In other words, SEs are for old men, Sports are for those a bit younger!![]()
5tephen said:My dad had an E39 530D sport and got rid of it, I now have an E60 530D SE but with sports suspension - mine is way more comfortable but is still as tight as be-damned when cornering or just when generally horsing the car around.
When the previous owner was buying my car from new they could've got the sport for only £1500 more or so, which is nothing compared to the total of all the other extras they added - they chose not to, primarily because of the comfort.
It definitely looks lovely in the flesh though.
[TW]Fox said:Sport adds:
Anthracite Headlining
18" MV Alloy Wheels
M-Tech Bodystyling
M-Tech Suspension
M-Tech Rear Spoiler
3 Spoke Sports Steering Wheel
High Gloss Shadowline
M-Tech Sports Seats
M-Tech badging on door sills, alloy wheels, steering wheel and gearstick. This means OcUK will think you are a chav pretending to have an M3 or something, whereas for everyone else it just adds a nice sense of occasion to the car.
It's basically absolutely worth having. Transforms the car - they handle brilliantly, look great, I wouldn't buy a non-Sport spec car.
bobert50 said:Ohh yours is a sport and a leather? Yea i'm sure they're comfortable regardless. Some of the e39's on high miles, especially the black leather for some reason seems to wear horribly in some of them? yet the grey leather generally seems in better nick ?
PedantNickXX said:Also adds interior black cube trim.
