3570k erratic temps
11 Oct 2008
Death Star
I installed the 3570k to my sabertooth z77 matched with a cooler master 212 evo and antec 1200 case and my temps seem to be all over the place.
core 0 - 38c
core 1 - 22c
core 2 - 27c
core 3 - 35c
on stock at idle.
also when i run prime 95 small fft the temps are
core 0 - 55c
core 1 - 47c
core 2 - 49c
core 3 - 51c
does this look right?
when I clocked it to 4.4 the highest temp was 68c at load.
I seem to have a large variance between cores.
the ivys do seem to vary a lot ive witnessed anything up to a 10c difference across cores on my 3770k
This is common on all intel quads, of the 5 ive owned theyve all had variations. It's very rare to see one with even temps at load or idle.
core 0 - 38c
core 1 - 22c
core 2 - 27c
core 3 - 35c
on stock at idle.
core 0 - 55c
core 1 - 47c
core 2 - 49c
core 3 - 51c
Thats perfectly fine, don't worry :)
The cheap thermal paste is the cause of the higher temps that ib cpu's run at. Other intel chips use solder between the heatspreader and cores.
