Built my system last night and it's running fine but the temps on my 3570k seem quite high (even before I attempt to OC).
Idling at around mid 50s and All 4 cores showing around 100 when I run Prime95!
Using Enermax ETS-T40 cooler which I believe should give good cooling performance. I did use an old tube of thermal paste.
Reckon it's worth taking the cooler off and using different paste?
It's a right pain in the arse to put the cooler on.
