No real upgrade path with either unless you go down the route of an i7 if you want hyperthreading. If you really want to push the overclocks and you've got custom watercooling you could get an i5-2500K but otherwise i would go for Ivy.
Is there any upgrade paths any-more, or am I always going to be stuck switching out MOBO with CPU upgrades![]()
For most significant CPU upgrades, that's pretty much the way these days.
That said, an i5 3570k or 2500k OC'ed will last a long time.
Bearing in mind they've got over 40% left in the tank and are handling stuff fine at stock.
CPU progression isn't all that fast at all really, I mean from the Core 2 quad's to IB's, I think IPC's somewhere in the region of 350% better (Although newer architecture and instruction sets can give significant advantages that result in higher performance gains than you'd typically get consistently)
What sort of games are most CPU bound one of these days?
Ive personally found bf3 to be a bit less cpu dependent than bfbc2.Battlefield 3 multiplayer is one of them
Do you mean that IB is around 3.5x faster than C2Q? That would make the performance leap huge. I had thought the IB performance increase was around 50% over C2Q at same clock speed?
I would go for Ivy (I did go for Ivy). I wouldn't regret not having an Ivy if I had a 2500K. Ivy is newer, that's why I got it.
Go with the 3570k. No real reason to go with the 2500k.
Other than it's cooler, cheaper and performs similarly?
