35mm on CD -what resolution
28 Oct 2003
Worthington-on-sea
Is there a standard image resolution when you get 35mm film developed onto a CD, as many high street shops offer?
And the key question: if there is, will it be a crappy resolution or something with a good bit of detail?
Cheers
Nelson
Cheers
Nelson
The question is, what do you want the images for? The one's I have done super quick at Boots provided jpeg images of about 650k-1000kbytes, at 1840 x 1232 in dimension. Is this enough? I was looking around most of the high street places last year and that was about as good as it gets unless you want to pay a premium at a certion 'photo' chainstore. This size, for me at least was okay for quick and dirty 6x4 prints, with a minimal amount of cropping, and also web use.
If you want more, you have to go to specialist places like www.peak-imaging.com where you can get develop and scan for about £7. This should net you a disk with jpegs of about 6mb on it according to their site, which is not to be sneezed at for the money. :) Of course they offer increasingly larger scans for increasingly larger amounts of cash.
Of course, nowadays, as you may have noticed in a thread about Kenya, I scan my own. It's the only way to be sure. ;) :D
MRK... Nope. You still have to get them processed. It's the light from the LEDs in the scanner. Plays havoc with your negatives otherwise. ;)
