360 power supply
Permabanned
15 Nov 2006
Is it multi voltage? As in can I take it to the US with me next month without fear of it blowing up?
I was intending on buying the Rock Band 2 instruments on the 360 cheap over there and then having a go on them whenever I have a bit of time inside.
I had the same problem when I moved my UK Xbox to Taiwan.
I just bought a second hand power supply for about £20, plugged it in and it worked straight away. Just make sure the output wattage is compatible with your Xbox.
It doesn't matter about the games themselves (can't go into detail about why), the instruments are a LOT cheaper though.
It costs 99 bucks for the Rock Band 1 kit with the game, that's insane. Although I'll pay a little extra to get the wireless kit, I bet it's still miles cheaper than the UK price of the original Rock Band stuff.
Ah, you're a thief or similar :p
I picked up a full RB2 set for £35 without game, and the drums are available for £20ish on the high street :)
A full RB set should cost you about 100$ :)
:eek:
Are those drums new then? Tempting to just get the drums now if fairly cheap and then pick up the guitar in the states.
I didn't know the RB2 set was wireless so I'm definitely going to pay a little extra to get them ones, shame I won't be able to make use of the game but I'll either just buy the instruments alone and if I do have to get the version with the game I'll just trade it in at Competitor or something and put it towards buying a PS3 game. :p
