360 Sound help
Fa-
Fa-
19 Jul 2006
Ok. so iv moved into uni and i have my 360 step up to my computers 24"ultrasharp.
but i has no sound :(
what options do i have for getting sound out of my 360? or speakers for my monitor ??
I'm guessing you're using it with the component cable, if so get a 2x RCA to 1x 3.5mm adapter and use that to connect it to your PC speakers.
Or buy a VGA cable that already comes with an adapter and use that (this will also give you much better picture quality on that screen).
