360 Wireless Adapter
27 Aug 2004
Geordieland
We are running a router that has a wireless access point plugged into it. Will the 360 find the internet alright with the use of the wireless adapter, or is there a certain way it needs to be set up?
Theres no security on the wireless. Aint get the 360 yet, but i might as well buy everything together when i buy it.
360 should find and connect fine, bit of setting up if you ever enable security but mine runs well on the network, streaming movies and tunes too!
best investment for my xbox i reckon, plugged in, tapped in password...no problems so far...not like my ruddy pc's wifi connection!
