360 wireless controller LED's stay on
4 Jan 2004
Nottingham
hey guys, i finally invested in a play and charge kit but when the controller and console is off quadrent 3 on the controller stays on (but dimmer) and quadrent 2 flashes in the same dim green colour?? but will go off for about 5 seconds if i press the guide button or the start button
whats goin off with it as its never happened all the time i've had the controller (bought seperatly to my console) but i was using normal duracell AA batteries
anyone else have this problem? i've been takin the battery pack out to stop it draining but its getting annoying
If I remember rightly, it is a common occurance (mine does it), it isn't an actual fault, and it won't significantly drain the battery life.
I was going to create a similar topic about this a while back but forgot.
Ever since I bought the 360 charger dock, and began using the rechargeable packs instead of AA batteries, I've also noticed quadrant 3 slightly dim on my controller when the 360 is switched off, but that's about it.
mine does it as well. i just leave the battery in. i've never noticed a decreased battery life as a result. i still charge mine about once a week.
Mine does, but it's very faint, it's only when a similar thread popped up when the 360 first came out that I took any notice, other than that it'd have simply gone by without knowing.
