3600 none X overcoock help
Permabanned
30 Dec 2021
Yorkshire
Hi, with my chip been a none x, I’m wanting to use the motherboards auto overclock options to boost the cpu.
I do t plan on braking and records lol but I want to get something out of it but I have no idea what I’m doing or where to start
my board is a msi b450m mortar max
My cooking is ample
What are the go too options in boost menu to set.
I've always found manually overclocking works best on the 3600. Set voltage to override mode and use around 1.3v then push up the clock multiplier as high as it will go, good samples should hit 4.4ghz.
