- 8 Aug 2010
- Oxfordshire
Processing D800e raws wasn't a huge issue.. but I could definitely notice the difference compared to my D700. Everything took 3-4 times longer. So my OCD and unwavering determination kicked in, and I began to look for a solution or work around that would allow the same control that I'm used to (Jpeg was not an option), but with better performance.
My system
Now my system wasn't slow by any means, however I recently downsized my main processing rig from a 4ghz+ i7 + raid SSD's, to a retina mbp 8gb ram with SSD. I only have a 512gb SSD which would have got filled up in no time considering the size of D800 raws. Because of this, I was planning on using an external raid 1 to store all my images. Ideally I also wanted the redundancy of raid. However I'v been impressed with time machine, and daily backups to different time capsules might be a solution.
My first thought was 'more hardware' was needed. However I'm pretty skint at the moment, so that wasn't an option. I tried different camera settings such as 'lossless compressed' and 'compressed' which got file sizes down to around 45mb & 38mb. This was better but I still wasn't satisfied, so I turned to google.
I tried out the DNG converter's lossy compression, and downsizing.
Weirdly I found downsizing actually gave larger files than full res, unless you downsized to less than 12mp.
12mp = 8mb
15mp = 12mb
20mp =18mb
36mp =10mb
Workflow
In practical terms, I will be converting Nefs strait from my SD card into a folder on my desktop. My rmbp tears through the conversion process, so it doesn't actually take any longer than importing in LR. Once images are on desktop, I then use lightroom to import into the catalogue. This takes only a matter of seconds as files are small, and being read from SSD. Once in LR, I can use all my presets and make edits etc. as I would do with a normal Nef file.
Free lunch
No. Obviously the lossy compression conversion throws some information away. The question was how much, and can I live with it?
To better see any differences, I used an under exposed Nef, and applied the exact same adjustments in LR to correct the image.
My findings, were that the dng's had a little more colour noise in the darkest of shadows.
Original
DNG
NEF
Original - 100% crop 1
DNG crop 1
NEF crop 1
Original - 100% crop 2
DNG crop 2
NEF crop 2
Performance
System is more responsive and snappy, it's too early to say for sure, but I would say these 36mp files are easier to work with than 12mp D700 Nefs.
Also while there is reduced quality in the shadows, there is still far less noise and banding than there would be with a D700.
Conclusion
Am I going to convert to DNG every time?
No, if I'm shooting a landscape, I will want every last bit of quality I can squeeze from the sensor. For wedding work however, when I'm dealing with more than 1K images, this will be very useful, and I don't need the absolute best quality possible, or even the whole 36mp. However as is seems to work better by retaining the same pixel count, I will gladly take the extra crop-ability.
Edit:
I have to test further, but high ISO files seem to be around 19mb.
My system
12mp = 8mb
15mp = 12mb
20mp =18mb
36mp =10mb
Workflow
Free lunch
Original
DNG
NEF
DNG crop 1
NEF crop 1
DNG crop 2
NEF crop 2
Performance
Conclusion
Edit:
