It's madness, buy a 5800X at least![]()
What GPU, resolution, refresh?That's where my default was but I wasnt convinced i'd notice much gaming difference with them... and if i'm going for a 5800x then perhaps it should be a 5950x no?![]()
Stick with the 3700X, it's fine for now. Then think about the next gen CPU next year.Has anybody made this switch or tried both? They seem pretty close but I wonder if the extra single thread oomph would give me more than the extra cores, particularly with VR?
Sign up for gpu alerts on discord, etc.Thanks all, sounds like I should be patient and just aim for a good GPU
Depends on the resolution you game at, for 1080p high refresh rate gaming the CPU is quite important but again you still need a strong GPU to take advantage of it.Does a CPU even contribute much with regards to a gaming setup or literally best to save up for a GPU resell?
I wish I kept my LG 34" but went with a Dell 34" ultrasharp but using my Dell 27" 1440p gaming monitor instead. Most likely continue to game at 1080p and see how bad it is compared to 1440p.Depends on the resolution you game at, for 1080p high refresh rate gaming the CPU is quite important but again you still need a strong GPU to take advantage of it.
Not gonna get much with my 970 card. Have to turn everything to low mode ha.
