3770K 4.6 to 4.8
30 Nov 2010
UK
Hi 8Pack,
Looking for some help. I bought a used 3770K and Board from the MM (user VaporMatt), he has benched this chip at 5ghz with very low volts (1.250v) and 4.8 at 1.224v IIRC so it's a good one. I have followed a few guides and got it to 4.6 with the following settings. Can you please see what you think of them and how I should go about pushing for 4.7 / 4.8 also I currently have my Samsung green at stock but would like to push them too once the CPU overclock is sorted.
Current Settings:
Testing:
Battlefield 3: Played 2 hours no problems
IBT: 10 loops passed
Prime95: ran for 30min with no issues
Also ran 18 passes of memtest for this memory
Max temp was 72c
Good post, will be watching this with interest. Im currently at 4.5ghz. @ medium LLC +0.05 offset. (temps under load in the late 50's/ mid 60s). Ram @ 1866mhz overclocked from 1600mhz
would like to see if this chip can reach 4.8ghz
Chris
I 2nd Good post !!
Yes I am also waiting for responce on this post...im in the same ball park as you both but im @ 4.5 @ 1.220 with temps now hitting ( after a reconfigure with cooling ) max 71 and while under full load id say average is 65...so I think theres alittle room for improvement :)..max 71 is after 2hrs Aida64 or prime I try not to use prime95 as ive heard it doesn't really test Ivy properly....
And is it because I haven't posted enough on here to warrant a signature ?? Can someone point me in the right direction for my bragging box ;)
Many thanks
DAN
settings look fine on the CPU side of things. RAM needs some work C11 1600mhz!!
Ok lets get CPU higher first. Try 4.8 at 1.3v and see what happens all other settings as they are.
4.8Ghz with 1.3v tested fine max temp was 85c though. Also when running IBT CPU-Z was showing the Vcore at 1.320v even though in BIOS it was set to 1.3v.
-EDIT ok so started at 1.3v so far I am down to 1.26 and still going, cpu-z is showing 1.264v-1.274 though when BIOS is currently at 1.260
Ok, so managed to pass IBT with 4.8ghz at 1.200v, I need to play some games to test it out but what do you think of the settings?
[/IMG]
Also why does it show 1.216V in CPU-Z when running Prime95?
Yeah very happy with it Matt, cheers. Just BSOD 17min in Prime 95, been playing around 20mins of BF3 no problem so far. Not sure if it's worth upping the Vcore one step and re doing Prime95 or just keep gaming and see what happens.
Have you checked the Event Viewer for WHEA errors or are you not to bothered about them? I'm in the process of overclocking my 3770K but I'll be nowhere near your volts. I need 1.2v for 4.5GHz during P95, and IBT.
Got a few WHEA ID 20 errors while doing Prime 95, I will play around again tonight might have to up the Vcore one or two steps to clear them. As for the chip I bought it knowing it was a good clocker.
Just up the Vcore man!!!! and then do sumat with that appalling inefficient RAM.
2133mhz 9-11-11-21 5-108-auto-10-6-26-6-5-7 TRRSR 4 1.65v
Ok, so tried the memory settings you gave they work fine, thanks. Should I try lowering the Dram Voltage?
Also upped the Vcore until the WHEA ID 20 errors stopped.
Screenshot:
Here are my current settings:
IBT tested for 10 loops
Prime95 for around an hour with no WHEA errors, the error shown was before I added one more notch of Vcore.
Played hour of BF3
Max temp: 79c (warm ambient temps and fans on medium)
Is my Vcore correct on the BIOS rather then CPU-Z?
Thanks for your help
Looks good to me. With that LLC CPU-Z will show higher Vcore under load. RAM timings look good DRAM Ref cycle time could be 108 I recon and you dont show TWCL but this can be 7 or even better 6 if possible.
In the third level RAM timings also manually set TRRSR to 4 if possible again for high bandwidth.
