- 22 Sep 2016
Hi there,
I'm a streamer and I've recently moved to a 2 PC system, using my old PC as the dedicated system.
It has a 3770K with all core overclock at 4.5ghz and I added a GTX 1650 Super to handle the encoding. It works really well...however I do have so5me issues occasionally with the CPU being maxed out when changing scenes if I load a complex website...and this can cause some rendering lag. Although I'm on a budget and only a small streamer, I take it really seriously (too serious probably ) and am a perfectionist...I want to reduce any kind of bottlenecking as much as possible.
I've been considering getting a midrange Ryzen CPU and some memory. I've already got a new X470 board that I got last year that I had to upgrade for compatibility issues and was passed the return period.
I was thinking for the Ryzen 2600 or 2600x which I can probably pick up for around £100 and some memory for £50ish. My question would be would the new gear perform any better?
It's got 2 more cores and 2 more threads, but lower clock speed. But then it would also have much faster DDR4 memory up from 1600mhz DDR3...and it's obviously just newer.
I'm not sure though whether it would be a huge difference? Am not really after a speed increase...just a better ability for the system to absorb increases in system load so's not to starve OBS of CPU horses.
Thoughts? Thanks
Thoughts? Thanks
