This is just a debate about these two cpu's.
To keep thing fair, I allowed the 9900k to have the same speed of memory as the 3800x but note the 3800x is more tighter timings (that is the 3800x's overclocking part). The 3800x is the cheaper system.
CPU: 9900k @5GHz - £499.99
https://www.overclockers.co.uk/inte...ocket-lga1151-processor-retail-cp-65j-in.html
RAM: G.Skill Trident Z RGB 16GB Kit DDR4 3600MHz RAM - 1.35 V - CAS 16-16-16-36-Timings £179.99
https://www.overclockers.co.uk/g.sk...hannel-kit-f4-3600c16d-16gtzkw-my-102-gs.html
Motherboard: Gigabyte Technology Co., Ltd. Z390 AORUS MASTER-CF £264.95
https://www.overclockers.co.uk/giga...cket-1151-ddr4-atx-motherboard-mb-576-gi.html
Operating system: 64-bit Windows 10 (10.0.18362)
Cooler Master MasterLiquid ML360R Addressable RGB CPU Cooler £149.99
https://www.overclockers.co.uk/cool...dressable-rgb-cpu-cooler-360mm-hs-080-cm.html
Total = £1,094.92
3D Mark Time spy CPU 11208. https://www.3dmark.com/spy/8579757
CPU: 3800x @ stock with Cooler Master MasterLiquid ML240R £489.94
https://www.overclockers.co.uk/amd-...ble-rgb-cpu-cooler-bundle-bu-016-cm.html#t=a5
RAM: 8,192 MB Team Group Inc. DDR4 @ 3,798 MHz (overclocked from 3600) £164.99
https://www.overclockers.co.uk/team...3600mhz-dual-channel-kit-black-my-08q-tg.html
Motherboard: ASRock X570 Taichi £308.99
https://www.overclockers.co.uk/asro...4-x570-chipset-atx-motherboard-mb-16m-ak.html
Total: £963.92
3D Mark Time spy CPU 11314 https://www.3dmark.com/spy/8740622
3D Mark Time spy CPU @ 4.5GHz 11721 https://www.3dmark.com/spy/8734959
CPU-z
9900k @5GHz possible that this system is not patched.
A-Data Technology 8192 MB (DDR4-2662) - XMP 2.0 - P/N: DDR4 3600 2OZ
http://valid.x86.fr/fi7tdc
Single Thread: 554
Multi-thread: 5823
3800x @ stock ABBA BIOS
Team Group Inc. 8192 MB (DDR4-2400) - XMP 2.0 - P/N: TEAMGROUP-UD4-3600
https://valid.x86.fr/rdg41u
Single Thread: 550 (max is 551 @ 4.5GHz boost just hard to get it in cpu-z after the multi thread test)
Multi-thread: 5829
This is not to say the 3800x will beat all 9900k system builds, the first main issue with the 3800x is the clock speed and RAM speed limit. Your maximum clock is 4.5GHz all cores, I have not seen a 3800x that can run safe voltage above this frequency. Also maximum IF most people can get is 1900 which leaves maximum RAM speed at 3800. With PBO set to motherboard limits, 10x scaling and +200MHz then 11400 cpu is possible in time spy, remember 11700 is approx. the maximum. You can hit over 26k in fire strike. https://www.3dmark.com/fs/20577914
The 9900k can add faster RAM and score higher. Note that most 9900k's can't go above 5GHz and of those 5GHz 9900k's most won't do much above 4.8GHz with AVX instructions. If you are very lucky you can get a 9900k that can do AVX instructions @ 5GHz all cores. Also things can get very hot with the 9900k and you need a very good AIO or full custom water loop for overclocking. The 9900k has no cooler, so you have to buy one yourself.
The 3800x is faster than a stock 9900k with IF 1800 and RAM 3600 with tight timings. This is possible with almost every 3800x I have seen.
9900K just has more overclocking headroom if you are lucky and get a good chip. Faster RAM with tighter timings allow for speeds possibly above the 3800x maximum.
It would seem that the 3800x could be as fast or faster than most 9900k's. Only when you get a very good overclocking 9900k with much more expensive RAM with good timings will you pull ahead.
Overall the 3800x is a cheaper opinion but is only better than the 9900k if most other games see the same performance I have seen above. Even so raw performance looks like it could be the same.
Total = £1,094.92
Total: £963.92
CPU-z
Single Thread: 554
Multi-thread: 5823
Multi-thread: 5829
