390 Idling/Fan Issue
Permabanned
23 Apr 2014
Hertfordshire
Got a Powercolor 390 in my sons rig and idling on the desktop its hitting 60-70 degrees, high usage though nothing is running. :confused: I tried changing the fan but every time I change it it spins up for a second or two then returns to 55%. Seems to be stuck on 55%.
Anyone had this issue?
What temps do yours idle at?
Tried driver cleaner and a reinstall, no change.
Cheers.
Ah, solved.
Had some kind of malware. Panda Cloud Cleaner sorted it. (Spyware terminator failed to find anything wrong).
Now idling at 38 degrees and can alter fan profiles. :)
