Permabanned
- 11 Jan 2019
- bedlam
Icue is running on mine and doesn't cause your issue on my system
All I know is uninstalling it made the system ideal instantly
If I change the power options to power saver in windows it clocks down to 2.16ghz & doesn't move from there. Any other power settings & the CPU stays at 4ghz.
Somewhere I read that this minimum should be set to 99% as this then allows the chipset/CPU to control downclocking. Seems to be working on mine nowCheck this. In windows power plan set it to high performance then go into advanced power plan setup and go to processor. Have a look at the percentage speed i cant remember of the top of my head but there is 2 percentages there. The minimum one should be set to 5 percent and the highest one should be set to 100 percent.
Its possible your having software issues and both these settings are at 100 percent so the cpu does not downclock.
If this is the case then you likely have something installed in Windows which is kicking the cpu frequency up.Yeah that is one of the first things I checked processor power management. Always used to do that on my Intel CPU.
Still the same with all the different options people have suggested.
[Edit:- I've gone through all the power options in windows, Setting them all to 5% min & 100% max, restarted & that seems to have finally sorted it!]
I just tested the Ryzen power profile at min 99% and the CPU does idle down as it should so something is causing it to stay locked at a higher frequency on your system.Not a clue to be fair, I did have SIV (some gigabyte software) installed which controlled the fans. But since I did the power options it has been fine, Its now stepping down & up just fine.
My PC (3900x) has just started doing the same thing, won't downclock at stuck at 4.3ghz all core despite 0% load.
