3900xt post and restart issues
20 Oct 2008
Hi, I’m hoping someone can help me,
I’ve purchased the following
3900xt
ASUS x570-f gaming
Originally team group 8 pack 3200mhz ddr4 now Corsair rgb pro 3600mhz
Corsair 750 watt psu
Corsair mp600
I’m having issues when trying to start the computer it gets stuck with the yellow memory led on the mobo, I’ve tried the xmp profile and without, loosend timings etc, sometimes it runs but will randomly switch off, occasionally when using but most often when left idle, when it reboots while idling it restarts to the bios as it no longer defects the mp600 nvme until I switch off the psu and start again. I’ve tried the latest bios which is prone to switch off while using and the bios one before that seems more likely to switch off at idle. I’ve upped memory voltage to 1.4 etc. Please help
Hi yes, cpu and most of bios is at stock, the only change is loading xmp, if I run without xmp the pc is a little better on restarts but still random crash when idling
Yes I swapped memory to the Corsair today, had issues when restarting, yellow light again I upped voltage to 1.4 letting it sit overnight see if restarts, the strange thing after random idle restart is the bios no longer recognises the nvme drive until I power cycle the psu.
