- 9 Jan 2008
- London/Camberley
Put it this way, since you're not overclocking, you don't actually need a high performance cooler but regardless of that, I assume you want something quiet. The H100 may be quiet in its lowest fan setting but something like the K2 is near silent because the fans can operate at much lower RPM. It just so happens that the K2 is also just as good in terms of cooling and much cheaper. Results in Sig. Plus the K2 has a massive base plate to accommodate the CPU. It's not just an opinion.
