As the title says-
First time building my own rig
Have i missed anything,would you change anything?
Already got the fans and fluid.
I'm only doing the CPU for now,will add a loop for the GPU's at a later date.
Will be fitted into a NZXT Switch 810.
All help and comments appreciated,this will be my first loop
thanks inadvance.
Hardware Labs Black ICE Radiator SR1 360 £69.98
XSPC X2O 750 Dual 5.25” Bay Reservoir Pump £59.98
Koolance CPU-370SI (CPU), Intel Waterblock £50.66
OcUK Tube Cutter Aluminum 3-14mm £8.50
XSPC HighFlex Hose 1/2" ID, 3/4" OD, 19/12.7mm, 2m, White £6.98
Koolance Nozzle Single, *Black* Compression for 13mm x 19mm (1/2in x 3/4in)
thanks inadvance.
