3930K overclocking with 1.25 Multi
10 Sep 2010
Cornwall, England
Yo yo yo gangsta's Wag1?
Anyway enough of that I'm trying to overclock my 3930K using the 1.25 CPU Multi rather than the stock 1.00 multi mainly because I want to see if I can get 2000Mhz RAM and a CPU overclock with less voltage than is needed when using a 1.00 multi.
I'm currently at 4375Mhz with 1.320V in BIOS and 1.28V under load, only tested for 10 minutes of OCCT but seems ok.
RAM is heavily underclocked whilst I overclock the CPU, RAM is running at 1000Mhz 9-9-9-24-1T @ 1.65V
Ok so the problem is if I up the core multi by +1 to 36 for 4500Mhz my PC won't boot even with 1.47V in BIOS, Tried all levels of LLC, Tried F3, F7 and F8 BIOS's, RAM is always underclocked...
I can get 4.6Ghz stable with 1.38V with the 1.00 Multi :confused:
What am I missing guys?
Oh and if I try and overclock the BLCK from 100 to 101Mhz my internet connection cannot be established, If I set it back yo 100 again its fine :confused:
Any help please! Thank you. :)
