- 20 Oct 2010
Hello,
Was just wondering if my temps are alright or if i have issues.
My spec:
3950x
x570 Aorus Master
2 sticks of Trident Neo CL16(the 3600MHZ Hynix ones)
Arctic Liquid Freezer II 280 AIO
Sapphire Nitro+ Vega 56 LM
Thermal Grizzly Kryonaut (if it makes difference as i didnt use the one Arctic gave)
Coolermaster c700p with 3 stock fans, 2 front and one back for exhaust. Planning to change these are loud and not sure they do much cooling.
So when running handbrake for example all stock (xmp on though) the temps on Ryzen Master show 70-74 degrees and runs on all cores roughly 3.9GHZ. Sounds also like the 2 fans of the AIO are running full speed although surprisingly they are not loud.
On gaming stock CPU its around 63 degrees
If i just try PBO on with Ryzen master temps go to 82.5 - 83 degrees and 4.0ish GHZ on handbrake, didnt try for gaming as i didnt think it would make any difference.
Didn't try the above with tweeking OC in the bios though and generally i want it stock as I want it to last long time.
Are the above numbers ok or do you think they are a bit much?
My spec:
3950x
x570 Aorus Master
