3com router help
Permabanned
29 Aug 2003
Hi guys, not too clued up on networking. Got a 3CR858-91 router, and can't get it to work with the net. I've tried running the wizard but it doesn't help me that much, will I need to phone telewest to get them to change the IP address from my modem to my router? :confused: I feel lost
nope and trying that lost my connection for 10 minutes, said that the network hadn't assigned IP address properly... windows tried to 'fix this' but failed. Few restarts later (PC & modem) and its working again, without the router... I know I've done something wrong somewhere but where?
If the machine wasn't getting an IP properly when it was connected to the router, it's an issue with the router.
is there a total dumb ass guide to setting up a router?
Can someone tell me what connection type BY is, either Dynamic IP or static?
I seem to remember my IP address changing at midnight last time I had BY just want confirmation
Biohazard said:
tis brand new out the box this morning? :confused:
So?
Dynamic.
Just to be clear:
  • The connection works fine with the modem directly connected to the PC
  • With the PC connected to the router, the PC doesn't get an IP. As a result, nothing works.
  • Does the router get an IP from the modem?
So its new out the box and should be bloody fine! :D grr
1. Yes
2. Is that PC connected to router, in turn connected to modem. Or just PC - router?
3. Who knows, I'll endevour to find out. As I said, networking is new to me
Right Mr Tolien,
PC connected to Webstar modem = 82.41.64.9
PC connected to router only = 192.168.1.2
next? :p
thanks for the help by the way, took me 20 minutes to remember the ipconfig line :( :p
:p told you the router was fine. BY must authenticate users by MAC address, cloned my MAC address onto the WAN port and works like a dream! :D
maybe I should give myself more credit than I do!
That was the whole point of switching the modem off et al that I mentioned at the start. :p
I didn't say it wasn't, but if you don't describe what's wrong properly...
Blueyonder use DHCP to assign dynamic IP addresses so your MAC address is assigned a temporary DHCP lease for an IP. The modem needs a reboot to recognise the different MAC address of the device plugged in so that it can make another DHCP request. Anyway, bottom line is that they don't authenticate by MAC or anything like that. A while ago you needed to update your account with the MAC address of the device the modem was plugged into and you could have up to 5 registered at the same time but they've got rid of that system now, thankfully.
I quite frequently plugged my Blueyonder cable modem into a router and directly into various PCs and it was fine without having to do any MAC cloning. I just needed to power the cable modem off and on again after it was plugged into a new device. Not sure why that didn't work for you but it should've done. Still, as long as you've got it working it doesn't matter.
I had already tried that, copying mac address was an option in the config page.
How can you describe properly something you have no idea whats wrong with until you fix? :p
lol anyways no worries all lights blinkering now fear my home network! :D
