- 8 Oct 2009
Hi,
I really need help on this as I've never built an HTPC before.
The HTPC will be used for the following:
This is for a home cinema, in which I have a 64D8000 3D Samsung Plasma, and will have the Monitor Audio RX6 AV12 speaker package with the Pioneer SC-LX83 AVR.
Necessary:
Not Needed:
The HTPC won't be used for any gaming or other activities... just watching blu rays, 3D and DVDs. Also I don't think I need a remote as I quite like the look of the Logitech Dinove Edge keyboard so will probably go for that.
Budget don't really know.. I can do 600-700 probably can stretch some more... but obviously as always, the cheaper the better
Any help is greatly appreciated.
Thanks
- Blu-ray
- DVD
- Blu-ray 3D
- XBMC or W7 Media Center. Either one will have TMT5 or Power DVD incorporated
Necessary:
- Intel i3
- Lian Li PC-C50B or Silverstone GD05 or Silverstone LC13B-E (still unsure about the case)
- Graphics Card - 3D and Audio passthrough over HDMI to the AVR
- SSD - I know 60 GB is probably enough, but I can stretch to a 120GB
- Blu ray reader (no need for writer)
Not Needed:
- HDD - Everything will be streamed from my Synology NAS
- Software - E.g Windows - I already have a new Windows 7 license which I will use for the HTPC
Thanks
Is it better a fanless psu? Or will it generate more heat? Also the fanless are more expensive than the 520W modular one I saw... but I guess they are quiter as well... Another thing, the X-460 is only 10 quid more. Would it be a better deal to get that (incase I wanna upgrade something later on)?
