- 1 Dec 2015
Absolutely love Loque Ghost S1 case. Pure master class in case design , though it price tag and aim to cater for the upper crust is hard to swallow .
Also noticed few things that won't be solve any time soon, can't take a 280 AIO and damn Coffee runs hot ! If you want to use an air cooler, your forced to go with very low profile and Non K chips unless you Delid .
Also, sucks if you like Zotac Amp Extreme or other long Triple slot flagship cards !
Also I didn't want to go and buy a SFX/-L PSU and the prices of them ...ouch
Spent some free time in work to quickly mock up a CAD render of the clone case, almost accurate for dimensions but need to do cut outs and the spine will be in 3 pieces, not one like the Ghost S1.
280/30mm rads in the top and bottom! 140mm long ATX PSU like Seasonic Focus units! and triple slot GPU clearance I think up to 310mm
Looks like clearance height for 80mm CPU cooler, seems a lot of show box designs were made/designed before coffeelake was on the table
Hopefully over come all the short falls of Shoe Box ITX cases I cant use
updated cut out top and bottom
SFX-L Vs ATX PSU
Got around to actually getting dimension of SFX-L right and ledge for GPU to sit and could PCIe cable, which would be 3D printed as part of the mobo tray .
Friend will be doing the printing and seems the Mobo panel will use 115c heat resistant material, the rest 60c
Think side panels will just be transparent acrylic . He's sent me different joints , did like the idea of the Mobo panel having .T joint at each and and slides into grooves with each end panel but will have to see .
Seems he can print this off cheaper then the damn PCIe cable haha
Again, this is a clone, not original but hopefully meets my end goal - though did explain Bitfurcation to him and damn that's half tempting , if cards aren't triple slot , might just make it ......
SFX-L Vs ATX PSU
