3D Printing and design. Help!
15 Aug 2011
Probably not the right section for this, but I need something designed and printed via a 3D printer, mainly for cost purposes.
Does anyone know where I could get this done?
Cheers
Maybe post it here or try the 3D printing thread in the printer sub forum. Someone might take it on for you.
Depending on what you need drawn I could have a crack at it. Could always use some more experience with CAD software.
Theres a 3d printing thread on the printers sub section.
Likely your going to have to draw it up though and create a 3d file for it.
Cheers guys.
Myknight.
This is the screen I want to fit in as thin a box as possible. I need to do some more measuring for two mounting holes on the back of it. Also, it doesnt show the HDMI connector on the left for depth.
I'll also post over in the print section.
Thanks again.
Should be simple enough. Assume you want the box opening to be flush with the edge of the screen?(76x109mm area right?)
If you can get back on the depth needed and the size of those screw holes for pillars(I want to say 6mm) then I'll have a crack at it.
I have posted everything over in the 3d print section mate.
Many many thanks, and yes the screen should be flush with the box if at all possible, I guess a couple of stand offs internally would be needed.
The screen sizes I have taken from here.
https://en.wikipedia.org/wiki/Display_size
