3d Vision Surround Project
25 Nov 2008
Anything i am missing from this list?
Asus GeForce GTX 690 4096MB PCI-Express Graphics Card £799.99
3* Asus VG278HE 27" TRUE 144Hz 3D Widescreen LED Monitor - Black £359.99
Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £259.99
BeQuiet Dark Power Pro P10 1000W '80 Plus Gold' Modular Power Supply £209.99
Adata XPG SX910 256GB 2.5" SATA 6Gb/s Solid State Hard Drive (ASX910S3-256GM-C) **OcUK Exclusive** £199.99
Gigabyte Z77X-UD5H Intel Z77 (Socket 1155) DDR3 Motherboard £173.99
Avexir MPower Series 32GB (4x8GB) DDR3 PC3-12800C10 1600MHz Quad Channel Kit (AVD3U16001008G-4CM) £119.99
You may! i did some reading based on your recommendation and can see that price/performance is better for the 670s but there are cons - such as power consumption, heat, overclocking overheads and some issues with unexplained lag...for the extra 20% or so..i would rather get the 690, knowing that i can upgrade to quad SLI in the future..
the funny thing is - i was planning on getting a macbook retina with a screen and it was more expensive than the rig mentioned.
Fair enough, it is your choice at the end of the day. :)
Also, the monitors you have selected come with Polaroid Glasses and mounts for spectacle wearers..
