So the motherboard will still be able to change the speed of the fan
As I understand it, yes.
like its doing now with a 4pin fan?
Not like it does with a 4-pin fan.
4-pin is PWM control
3-pin is voltage only control.
From Page 56 of your manual (available online as a free PDF from Gigabyte website):
CPU Smart FAN Control
Allows you to determine whether to enable the CPU fan speed control function and adjust the fan speed.
Normal Allows the CPU fan to run at different speeds according to the CPU temperature. You can adjust the fan speed with EasyTune based on your system requirements. (Default)
Silent Allows the CPU fan to run at slow speeds.
Manual Allows you to control the CPU fan speed under the Slope PWM item.
Disabled Allows the CPU fan to run at full speeds.
Slope PWM
Allows you to control the CPU fan speed. This item is configurable only when CPU Smart FAN Control is set to Manual. Options are: 0.75 PWM value /oC ~ 2.50 PWM value /oC.
CPU Smart FAN Mode
Specifies how to control CPU fan speed. This item is configurable only when CPU Smart FAN Control is enabled.
Auto Lets the BIOS automatically detect the type of CPU fan installed and sets the optimal CPU fan control mode. (Default)
Voltage Sets Voltage mode for a 3-pin CPU fan.
PWM Sets PWM mode for a 4-pin CPU fan.
Note: The Voltage mode can be set for a 3-pin CPU fan or a 4-pin CPU fan. However, for a 4-pin CPU fan that is not designed following Intel PWM fan specifications, selecting PWM mode may not effectively reduce the fan speed.
Clear as mud?
