4 fans running on Cpu header/headers ?
13 Feb 2009
London
Hi,
Need some advice please ;)
I have a Raijintek Triton Cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-016-RT
I'm changing the fans for 4 of these Aerocool DS Edition Fan - Black - 120mm
http://www.overclockers.co.uk/showproduct.php?prodid=FG-040-AE&groupid=701&catid=2331&subcat=4
But i want to run 4 fans from the cpu header, i noticed next to the cpu header there is a cpu optional.
What do i need to do, buy 4 way PWM fan splitter to run of the cpu header?
Or do i need a 2 way splitter?, and run 2 of the cpu header, and the other 2 of the cpu optional header, like the ones in the link below?
If so, what are to 2 differences from the 2 splitters?
BTW, My motherboard is a Asus Maximus VII Hero Intel Z97
http://www.overclockers.co.uk/showproduct.php?prodid=MB-608-AS&groupid=701&catid=5&subcat=2811
Akasa PWM fan splitter
http://www.overclockers.co.uk/showproduct.php?prodid=CB-071-AK
EK Water Blocks EK-Cable Y-Splitter 2-Fan PWM
http://www.overclockers.co.uk/showproduct.php?prodid=WC-551-EK
Cheers Guys :)
I'd just get a 4 way splitter that draws power direct from the psu, that way you don't run the risk of pulling too much power through the motherboard.
Get one of these: http://www.overclockers.co.uk/showproduct.php?prodid=CB-031-AK
That will let you connect three fans then connect it to the CPU header, then connect a molex to power them all (so the is no risk of them overloading the header).
Connect the fourth fan to the CPU OPT header.
Or get two of these like you though:
http://www.overclockers.co.uk/showpr...odid=CB-071-AK
And connect two fans to CPU and two to CPU OPT.
EK charge more for their one.
OK Excellent! would the Cpu opt run at the same RMP as the Cpu header
Thanks for your Help :)
