- 20 Jan 2012
Is this possible with Nvidia Surround
If I have two GTX 4GB 680's to use in Surround mode with three displays, can I add a 4th display to run in non-surround mode at the same time.
The three monitors in surround would be 1920x1080 (5760x1080) and the other monitor 27'' 2560x1440.
Has anyone got something similar set up I'm thinking about this but not sure if it's a good idea/or just a waste of money (that I'm willing to spend either way)
Monitors for surround - Samsung Eyeinfinity Bundle - 3x S23A700D
27'' Monitor -Hazro HZ27WC
on there and from a review
yeah seems the configuration is much simpler than I was anticipating it's as simple as making sure two other connections for the surround set-up are on the same GPU doesn't get any easier than that.
