EDIT
Ok....never mind, Windows Explorer just decided to restart on me, which seems to have interupted the Checkdisk process, and now, the drive shows up as it normally should in file explorer...where as before, while i was running checkdisk (and before i ran it), it just showed the Drive letter, name and Format, no capacity information, but now, it is.
Though Crystal Disk keeps giving me temperature warnings (50-53 degrees), but i'm assuming that's normal operating temps for it, since i'm not getting any other warnings....apart from HD Tune Pro showing a C7 Interface CRC Error message (Current: 200 Worst: 200 Threshold: 0 Data: 9 Status: attention" showing that there seems to be a problem with the data cable. It's a USB 3 cable plugged into a USB 2 port, there are two USB 3 ports on the front of my tower, but they're not connected to anything, as my board doesn't support USB 3.
Then again, the errors could have been caused by the drive being starved for power, since i had USB Power Suspension turned ON in power management, until a couple of weeks ago, when i found out that can damage external USB drives. (and freaking out because the drive was being recognized as RAW format, and the two USB pen drives i have as extra backup weren't being detected at all)
