£400 Build Spec Help
17 Feb 2010
Newry
Hi there. Thanks for viewing this thread. My friend wanted to build a pc for around £400 and I wanted some input from you guys.
He needs a complete system apart from monitor and optical drive. He mainly would use it to play World of Warcraft, and wants a nice gfx card capable of running it on highest setting, or somewhere close included in the £400 build. I am not sure if any of the onboard gfx cards would run it. So i know this is a big ask for a £400 system.
I am sure he will want to play other games on it at some point, so your input on a gfx card to allow recent games to be played would be greatly appreciated.
Any and all suggestions are welcome, and either amd or intel, whichever you think is best.
Oh and I seen that sandy bridge review, would anyone recommend this for my purposes?
Thank you so much, awaiting your knowledgeable ideas!
Does he need operating system, keyboard, mouse and speakers included in the price? Also is he a student? (eligible for a cheap copy of Win 7)
Oh sorry I forgot to mention that he doesn't need speakers, mouse/keyboard, or operating system. Whats needed:
Case
Power supply
Motherboard
Ram
GFX Card
Hard Drive
Processor
Thanks
Tiny bit over budget but I think it's worth the extra £27:
Asus ATI Radeon HD 6850 OC 1024MB GDDR5 PCI-Express Graphics Card £137.99
(£114.99) £137.99
(£114.99)
AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail £101.99
(£84.99) £101.99
(£84.99)
Coolermaster Elite 430 Windowed Case - Black (with 500w Elite Power PSU) £64.33
(£53.61) £64.33
(£53.61)
Asus M4A78LT-M 760G (Socket AM3) DDR3 Motherboard £49.99
(£41.66) £49.99
(£41.66)
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) £30.98
(£25.82) £30.98
(£25.82)
OCZ Platinum 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Ultra Low Voltage Dual Channel Kit (OCZ3P1600C9ELV4GK) £29.99
(£24.99) £29.99
(£24.99)
Sub Total : £346.06
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.00
VAT is being charged at 20.00% VAT : £71.21
Total : £427.27
Wow that system loks amazing. Thanks for the input. Do you have any thoughts on an equivalent intel system, as in motherboard and processor?
Do you think he will need any more cooling with that system, and will the power supply hold out alright with that card?
Thanks for the quick response!
I assume that the OP already has an optical drive to use in the build.
If you want to stay within budget I would get the following parts:
AMD Athlon II X3 450 ~ £60
http://www.overclockers.co.uk/showproduct.php?prodid=CP-282-AM
MSI 870-C45 ~ £55
http://www.overclockers.co.uk/showproduct.php?prodid=MB-147-MS&groupid=701&catid=1903&subcat=1481
OR
ASRock M3A770DE ~ £53
http://www.overclockers.co.uk/showproduct.php?prodid=MB-034-AK&groupid=701&catid=1903&subcat=1481
The cheaper AMD 880G based motherboards use the same SB710 southbridge found in the 770 motherboards.
4GB 1600MHZ DDR3 ~ £30
http://www.overclockers.co.uk/showproduct.php?prodid=MY-221-OC&groupid=701&catid=8&subcat=1517
However,OCZ is leaving the RAM market so maybe it would be worth spending some extra money on another RAM kit.
Samsung F3 500GB ~ £31
http://www.overclockers.co.uk/showproduct.php?prodid=HD-081-SA
BeQuiet Pure Power L7 530W ~ £43
http://www.overclockers.co.uk/showproduct.php?prodid=CA-042-BQ&groupid=701&catid=123&subcat=
Coolermaster Elite 370 ~ £34
http://www.overclockers.co.uk/showproduct.php?prodid=CM-023-CM&groupid=701&catid=7&subcat=
MSI ATI Radeon HD 5850 Twin FrozR II 1024MB GDDR5 ~ £135
http://www.overclockers.co.uk/showproduct.php?prodid=GX-103-MS&groupid=701&catid=56&subcat=411
OR
Asus ATI Radeon HD 6850 OC 1024MB GDDR5 ~ £138
http://www.overclockers.co.uk/showproduct.php?prodid=GX-241-AS&groupid=701&catid=56&subcat=1866
I have avoided the Coolermaster Elite 430 and PSU combination since the Coolermaster Elite Power 500W uses a passive PFC and is not very efficient.
The total comes to around £386 to £391 excluding postage.
I really wouldn't bother with an Intel build at this price range, it's not enough to afford a Sandy Bridge build with a half decent graphics card and there's not much point going for an i3 1156 socket build these days.
Power supply wise that one is absolutely fine for that graphics card and CPU (I wouldn't have suggested it otherwise). As Cat says it's not the most efficient model in the world, however I still consider it to be pretty decent value for money.
when building my system a couple of days ago (came out at £445) i found that at this price range AMD seemed to offer better value for money, however, im happy to be proven wrong here
i went with a very similar build to yours, but i needed a DVD drive and keyboard, hence the extra price
Don't know about you but I never plan on trying to run my PSU at 100% load. :p
It depends on whether at lower loads the Elite Power units exhibit the same characteristics.
OTH,as part of the PSU and case combination you are paying around £26 for the 500W Elite power PSU so it is probably not fair comparing to more expensive units though as they are around £35 to £45.
