400 MS Points - Best way?
12 Dec 2005
Hi guys,
I want to get 400 MS points so I can purchase the trials HD addon pack,
Is it possible to purchase just 400 points or would I need to buy a 1200 card? Don't really want to do that because I wouldn't have anything else to spend the points on.
Cheers
Im pretty sure 500 points is the lowest you can get. I cannot remember. It should only cost you £4.25
