4090 Vertical mount
9 Feb 2024
NW UK
I am wanting to vertical mount my Gigabyte RTX 4090 Gaming OC in my phanteks enthoo pro II case. I'm not sure which vertical mount if any would be compatible. Has anyone hhad experience of doing this with an enthoo pro II?
Because Phanteks aren't the only manufacturer of vertical mounting kits, and half of phanteks stuff is out of stock in the UK including the nice Argb one that has a support bracket built in for longer cards, which mine certainly is.
*Clarification: I have emailed phanteks but am interested in universal kits etc too*
I’ve had a Lian Li XL mount that was specific for my case…. and it was absolutely rubbish compared to the mount I have from EKWB, which worked well with all the 4090s I’ve had including the whopping Aorus one - all 4090s got sent back though because they were noisy or had defective fans.
It was an EK-Loop Vertical Holder. Really good because it fixes to the motherboard screw holes on the far side from the HDMI connections, so absolutely no sag.
