40d - Remote Shutter
13 May 2010
Hey Guys,
I've recently acquired a 40d , but the remote trigger i previously used with the 350d won't work, It works fully with the 350d when plugged into it, but when i switch the cable over for the 3-pin 40d Cable, It lights up the same, but the camera does nothing, as if it doesnt register.
Is this enabled in a menu somewhere? (Still getting to grips with it) or do you think it's a faulty cable or (hopefully not) a faulty remote port?
Any advice appreciated!
Just tried that, doesn't change anything...
Might see if I can get the supplier to post a new lead and see if it is that... Hope it's not the port!
