Can't find a better link but Xbox 360 does not upcale, it just outputs 480p
http://forums.xbox-scene.com/lofiversion/index.php/t487635.html
HEADRAT
HEADRAT
But the xbox360 gives a very bad picture on normal DVD's...HEADRAT said:Erm well I'm not sure about upscaling DVD players but I know the upscaling via my MCE2005 gives a much better picture than my Xbox 360!
HEADRAT
HEADRAT said:Snip
Apparently the Xbox now does upscale due to an update!
HEADRAT
ashagplz said:....what resolution do sky broadcast HD at?....
Cyber-Mav said:only time HD will look good is when you have the entire program on a HD dvd or on your hard drive.
crunchman said:It only upscales if you are using a VGA cable.
I can only compare it to my Pioneer DV-575 via component, but the xbox definitely wins hands down.
ashagplz said:which panasonic model?
any idea how it looks through a skart?
