4200+ Overclock help
13 Mar 2005
Ive just bought this chip ....Upgraded from a opteron 144 which i had @ 2.4ghz
id like to clock this chip a little to say 2.6 if possible
Im running a dfi lanparty
If i change the
FSB FREQ = 240
LDT /FSB = X3
CPU / FSB = X11
And up the vcore to 1.4
what would i need the ram divider set too?
3/4
Thanks
Will_3rd said:
try and make the ram run at stock or just above, does your board give you the current DDR speed?
Hmm not too sure about that....where would i find that ?
Thanks
fsb - 265
ldt ratio - x3.0
ldt width - 16 16
cpu/fsb - x9
pci exp - 100mhz
cool n quiet - disable
cpu startup - 1.425v
cpu vid control - 1.425
cpu special control - auto
ldt voltage - 1.3v
chipset voltage - 1.5v
dram voltage - 2.6v
dram config:-
dram freq set (divider's) - 133=ram/fsb:03/04
cpc - enable
Ram cas latency - 3
^^^Thats what i had with my opty 144 which i got the info from here...so thats what im working off really
03/04 divider is 199mhz which is pretty bang on with the ram
try setting your ram divider to 180 which will set your ram to 220Mhz then run memtest to see if you get errors, if you do then you may want to set it to 166 instead which is around 188Mhz.
I have my 4200 at 2.6GHz by using 4x HT, 10x multi and FSB 260. RAM is set to 166MHz (5/6) which works out at 216MHz. My VCore is at 1.375V.
Thanks guys.....ill have a go in a bit
Sorry may be a dumb question but whats 4x HT on a dfi board ?
Thanks
