I wish I could. Any overclock .even to 4ghz gives me a blue screen. Not sure whether my mobo is awful or my cpu is literally the worst of the worst.Based on the things you want I would buy the gpu and overclock the poo out of your cpu
Pick up a used 4790k,
wait till summer on the cpu change over if you upgrading doesnt matter about the gpu. as you will upgrade anyway. will be miles better than what you have now. while you wait.
no point getting 2600 now.
Vega 56 is faster stock for stock.
Vega 56 is faster overclocked and undervolt VS overclocked.
Vega 56 has 8G vs 6G
Vega 56 has more memory bandwidth
Vega 56 supports all free sync monitors not just some
Vega 56 cost less
Vega 56 comes with more games.
It really is a slam dunk!
Or grab a Vega 64 from £389.99 !
AMD are totally owning the sub £500 bracket at the moment!
Vega 64 @ £400
Vega 56 @ £320
RX 590 @ £250
RX 580 @ £200
RX 570 @ £150
All with 8G, winning every price segment for performance and value for money in my opinion.
You should be able to get 4.2Ghz absolute minimum out of the 4670k with that mobo and decent air cooling, 4.4hz for something like 95% of chips.
I'd consider a Vega 56 instead of the 2060 if you plan to tweak it. To quote Gibbo:
There is no minimum OC.. He could have poor cpu, mobo, ram or all 3.
I had an i3 6100 that did 4.5, then I got a new motherboard that should have been better but only get 4.2Ghz
im not quite sure whats causing my poor overclock. my ram is supposed to one of the best for overclocking although ive never tried that either. ive just never been able to get much out of it.
What I mean is on most chips there's a certain OC that 99.9% of chips will reach at a given Vcore, if you check out https://siliconlottery.com/pages/statistics They have statistics of what % chips they've binned hit a certain clock speed and they bin thousands. Every CPU has to perform over the stock settings otherwise the mildest degradation would mean Intel would be constantly dealing with RMA's which would affect their bottom line. Not to say there couldn't be Mobo or ram issues.
