Hi Gents
got myself a 4770k running with a h100i so I thought I would test a bit of overclocking. a bit of a chicken so I thought I would use the gigabyte easy tune tools to start off with...
When I pop it upto 4.1gz (light) it all seems ok and temps go high underload (IBT) maybe around 60c... (not to bad I thought?)
When I push it higher medium 4.3ghz or extreme 4.5ghz though it goes very got,,, late 90'sc
I was thinking that maybe reseating the cooler, however I have very good idle temps 25-30c so I did not think that was the issue. I just did use the stock compound on the h100i though so perhaps this is not good enough for the higher overclocks?
Just wondered what your thoughts were?
Thanks
Thanks
) in normal usage so the CPU wont get as hot as that.
