My PC. In sig is struggling to play BF4 at Max settings. GPU Usage is around 60% while my CPU Maxes out at 100% while playing. I think the CPU is holding it back.
I have heard BF4 benefits from Hyper threading/additional cores.
Would you go for the relatively expensive 4790k or go for X99, motherboard changes would be required but that's not a massive problem. I can sell my current equipment.
Ill keep on with it for a while. Then I will save my pennies and buy a 980ti guessing all brands are about the same now. In terms of quality.
