4790K too hot ?
10 May 2012
North London
OK I was on BF4 a little while ago and yesterday Assetto Corsa, my CPU was getting very close to 80c ( 78c )..is that OK ?
Also idle temps right now are around 36-38c , with no OC .
Well the weather is hot... Do you know what your typical temperatures are?
The 4790k is a reasonably hot CPU though.
Yep deffo the weather, room temps will be up around 10-15c so add that into your CPU temp. As long as its safe and not in the 80-100c I would not worry
