It only works for me if it says Microsoft Default Display Adapter in the device manager, if you have used DDU then it should. Do you get the package failed to install message, it hides behind the installer window but if you look at the task bar it has a second icon which is the error dialog.
I couldn't tell as the screen stayed black.
changing to 1080p output and going to try again
