4850 fan speed
There is a fix in CCC that you can do.
Open Catalyst Control Centre and enable ATI Overdrive.
Open profile manager, make a new profile and save it.
Go to C:\Users\UserName\AppData\Local\ATI\ACE\ and open the xml file of the new profile in notepad.
It should look something like this.
Code:
<Feature name="FanSpeedAlgorithm_0">
<Property name="FanSpeedAlgorithm" value="Manual" />
</Feature>
<Feature name="FanSpeedRPMTarget_0">
<Property name="Want" value="0" />
</Feature>
<Feature name="FanSpeedPercentTarget_0">
<Property name="Want" value="25" />
Change the FanSpeedAlgorithm value to 'manual' and the FanSpeedPercentTarget value to whatever fanspeed you want.
Save the file and reload it in the control centre.
Code:
</Feature>
</Feature>
Thanks for that and bloody hell its loud at 100% speed lol
When i make a new profile, it doesnt show up in the ACE folder?
Any ideas why?
I had the same problem some of your files are hidden
Go to control panel
Then open folder options (should be at top my one was )
Then view
Then look for the name (hidden files and folders)
Just tick show hidden files and folders :D
