4870 adjust fan speed
6 Jul 2006
co durham
ive tried installing the latest ati tray tools but says something about driver signature and cant find a setting in the CCC panel to adjust it as it is running at 76deg,any help please
if your using vista 64, you'll need to disable driver signing on bootup (F8)
and then go and install ATI tools
You can disable dirver signing permanently by going to a dos box and typing :
bcdedit.exe -set nointegritychecks ON
or
bcdedit.exe /set nointegritychecks ON
one of the 2 !
