4870x2 cooler
you know i did even think to look if its been posted before!!
How stupid of me!
I should have guessed really, bet loads of us are waiting for it!
The 5870X2 will be out by the time this cooler goes on sale.
I would've gone for water if the block wasn't so pricey. Oh well, technology marches on. Maybe I'll be able to overclock the next one :)
my only worry with it though, is that the hot air is not blown out of the case, so surely it'll increase case temps loads??
I cant even use mine in this weather and it's mild outside really frustrating can only use it when it sound like im ready to take off, and i have good air flow :eek: i will buy a cooler if it becomes available.
There's a waterblock in the clearance section for the 4870X2...cheap as chips...altho it was only one in stock so may have gone by now...of course I am thinking of getting it...but if its gone I will happily take the one priced at roughly £88...but Arctic Cooling want to hurry up and release that cooler instead :D
I was looking at the same thing as i already have a water cooling set up but just don't see the point as i should be able to use my card when i like without extremes of temperature coming form the card, wish i knew that but i did build my pc in the winter so temps weren't a problem then.Roll on 5870x2 i say
If the price is good then I will certainly jump for the 5870X2...and then it means I can just move my 4870X2 to my Q6600 machine which currently uses HD2600XT lol :D
