4870X2 Heat...!
I thought the 2GB was split so each GPU got 1GB and so it's only effectively a 1GB card because of the whole crossfire thing?
That's what I meant, even though it's a single card physically you still get a lot of the problems associated with xfire so rarely utilise all 2gb (in my experience). I've noticed a difference switching to a 'true' 2gb card.
Yeah the 4870X2 is hot and noisy under load, i gave the card to a family member but the 5970 is just as noisy and as hot.
Remove the plastic shroud and just cable tie a 120mm/2 80mm fan(s) onto the exposed alu heatsink - that should help. Hell, if it doesn't help then it's only set you back the cost of a few cable ties and you can put the shroud back on.
TBH it didn't actually improve temperatures when I tried that, BUT it did significantly decrease the noise :-) (TBH that could be because I wasn't using the X-Brackets at the time).
Those Arctic Accelero coolers do look damn nice. Not that mine has needed it but I kind of wished I had put one of those on, even if only for the noise when under load.
I was in the same position, and as the card was only worth about £100 (give or take), I couldn't justify spending almost another £50 on a new accelero. Watercooling ONLY if you already have a partial setup, or just Ghetto cool it :-)
