- 29 Nov 2010
Hi everyone, my 4870x2 is currently giving me a serious headache, I bought it second hand and immediatly wanted to water cool it, I checked that it was working by playing a few games and I had no problems. I then modded the 4870s heatsink so that I could fit two zalman gwb3 water blocks to it.
Once everything was put together I plugged it into the loop and straight away got serious artifacts I tried cleaning my drivers and installing the new drivers but the card still showed big white lines when in bios and windows.
I put the stock heatsinks back on without the shroud and turned the pc on, artifacts were still showing but because there was no shroud on the card overheated so I shut down the computer and placed a fan on the heatsinks, started up again and everything was fine and games played perfectly.
So thinking it may be the zalman blocks I decided to stop being cheap and bought a full coverage xspc razor water block. Same thing occurred with this block. I loosened the screws around the edges and a bit on the inner gpu screws and it booted in fine and went into windows fine. But 10 minutes into playing a game the pc freezes. The screen goes black and the computer restarts.
So my question is, is this a new problem now such as an old bios or maybe wrong ram voltages?
Also just to let you know when I test default clocks using the custom clock test on CCC it fails. I haven't tested it with stock HSF on.
Thanks in advance
Thanks in advance
(you are using paste right?)
. From the problems stated and very short fix does anyone know what the problem is?
